if it's copper heatpipes or aluminum it will make a mess.
Because the caps are just under the lid which means it would be really easy to brick the card. Intel's processors have zinc coatings on their IHS but the Liquid Pro doesent damage that, so why would it damage the nVidia IHS?
No one makes 0.25mm pads that I know of. I could replace the pads with TIM, but that might just make things worse. Maybe I could replace the GPU TIM with a pad. That might be a better option.
no, most pads are terrible performers... not good enough for the main GPU... you really need a shim or thin copper sheet or foil, depending on how much thickness is needed.
Even an IHS recycled from somewhere might an option. Worst case: cut a section out of a (metal) cookie tin. Or use a razor blade (which is steel).
The guys in the Peltier section have experience with those kind of thin shims, sheets et all although they call them hot plates & cold plates
Have a look overthere
Check for dimensions / thickness:
http://www.frozencpu.com/products/14971/ex-blc-1051/EK-VGA_Supreme_HF_HD7970_Cu_Adapter.html
http://www.frozencpu.com/products/20764/thr-217/Pure_Copper_Thermal_Shim_-_20mm_x_20mm_x_05mm.html
http://www.frozencpu.com/products/20761/thr-215/Pure_Copper_Thermal_Shim_-_15mm_x_15mm_x_05mm.html
Note that dumping the pads completely an using a non-conductive tim like ic-diamond is an option... but you'll have to do several mounts to find out if there is contact everywhere.
