_Cyberpunk_
- Jun 1, 2013
Okay, I am having a bit of a problem choosing a chassis for my next build. I have looked at hundreds of full tower cases and the only one that fully satisfies me in terms of aesthetics is the Corsair Obsidian 800D. It seems to be common knowledge that this case is utter trash when it comes to air cooling and I don't want to take the risk of water cooling, not even a closed loop system like the H100. Searching for the issue on google I have come across multiple threads where people were having the same issue, trying to make it fit for air cooling (even on this very board, but I didn't want to necro the thread). So here is my question, do any of you guys have experience with air cooling the 800D with different fan configurations? I was considering using Corsair AF series fans. Here is my mock up:
I am mostly concerned about my three graphics cards not getting enough air. Is there any way to have more air flowing in from the bottom? Also I am not quite sure what I should do with the third top fan. I figure that it would be rather useless to use it as an intake, but using it as an exhaust is even more concerning. Is it a bad idea to exhaust air right next to an intake? (I also want to use a magnatic 380mm radiator dust filter on top, which could cause some problems when having one fan set to exhaust)
I also intend to overclock my CPU which is very likely going to be a 4770k to around 4.7 GHz, depending on the heat and required vcore as supposedly someone managed to OC it to 5GHz at just 0.8V. I am also going to OC the 780s but only within the stock voltage configuration. Do you think this kind of build would be possible, or would the temps (and noise) be abysmal?
