So, I recently decided to scrap my old water cooled rig and switch it up to a Corsair Carbide Cube case, the 540. I liked the idea of these cases but am now left with a few questions
I want to fit a 3x120mm+2x120 rads in the system. Cooling a Single GTX 980 and i5 4690k for now, may add another 980 later. Going for moderate cooling but quiet and stylish.
Any recommendations for fans? I have 2 Corsair SP120 High Performance fans kicking around and was figuring on adding more of those to each setup. I know the gentle typhoons are amazing but they are incredibly expensive and I can't find the good ones anywhere anymore.
Also, would this be too much Rad Space? I did a water cooling rig before and it turned out moderately well but figured I'd do some more in depth research for what I need for this rig.
Pumps and Rads. Any pumps to look out for and RAdiator. Was going to go with the Alphacool NexXxoS UT60s for both my 240 and 360 since I heard they do well with low RPM fans. Any recommendations there?
Thanks
Thanks
