- Jun 12, 2018
- Mazowsze / Nottingham UK
Good Evening lads,
While trying to achieve sufficient temps, clocks and performence i decided to change me Cooler Master EVO 212 fr something more "cool" cooler
Ive just spend hours tossing and turning, trying to fit it on top of the case ,and although case is massive wide and large, motherboard and drives cages wouldnt allow to do so, only damaginf the case.
The Case Sharkoon D28 if i recall it correctly comes from my very first gaming rig from 4 years ago.
Would please post a list of available cases in UK that will accomodate mentioned above cooling system,
Well i ont want to spend more than ... well i'd like to use as cheap as possible case that can be fitted with h115i , it doesnt really matter if in front of case or top of it, me personally would like to put it on top, so i can put 2 or free fans in front pulling the air into .
It'll be muchly appreciated if theres such a list and/or if u can provide ur feedbacks.
Kind Regards
Kind Regards
