Hello everyone, I'm new to these forums and relatively new to overclocking.
All I've done in the past is overclocking my Intel C2D E6600 to 3 - 3.2 GHz on the stock cooler. (Yeah, was pretty hot )
Now I just purchased the H60 cooler. I know I should have gone for the H70 or H80 but the H70 wasn't available and the H80 was a bit too pricey...
I've the AMD Phenom II x6 1090t now, and I'd like to know if this cooler will handle 4.0 GHz on this CPU...I pushed it to 4.0 GHz but had problems! Measured temps with CoreTemp and it only went as far as 43 degrees at full load on P95 and then I got a BSOD! It also went as far as 42 degrees on stock clocks and when I tried 3.5, I got an error on one core in P95... So I'm confused.
I overclocked using the multiplier and added added some voltage. My default voltage was 1.45V (Isn't that much? :/) and I went as far as 1.5V. Didn't have time to test it more, I'm at work right now and when I get home I'll mount the cooler more properly and try again.
Any help appreciated, thanks in advance!
