I really can't agree with your recommendation on the Cooler Master Hyper 212+. I've tried one and it was junk/rubbish. Temps were consistently higher than my Thermalright Ultra 120 Extreme and Corsair H60, by 8-10°C. It just doesn't have enough thermal mass (metal to conduct heat away) or heatpipes to compete with higher-end air coolers (not to mention the TRUE is the same price as the 212+, or lower on the used market in the USA) or lower-end All-In-One liquid coolers.
The Noctua NH-D14 seems decent though.
To the poster of the thread, I've owned two H60's. They're a decent cooler, but meant for lower power chips. I used them with Intel Core 2 Duo and Core 2 Quad chips (LGA775 socket) and they worked fine, but the H60 really can't transfer the heat fast enough with LGA1366 i7 chips (they tend to run hot). It's also a decent cooler for lower-end LGA1155 quads (locked i5, maybe locked i7). Tried it with my i5 2400 and it worked fine.
I've also had a Corsair H80, H80i, H100 and H100i. All have been good coolers. The H100 and H100i generally have a faster, more efficient heat transfer than H80/H80i. They are a good choice if the case can fit a 240mm/2x120mm radiator.
Don't know how you snapped the screw off, didn't know it was possible to get them that tight.
