Hi guys,
I need a corsair link cable to connect pump unit to a usb on the motherboard via micro ish on the pump.
Is the lead just a standard 5pin to micro usb lead?
If so I can find that easy enough
Cheers!
James
I'm not sure but dependent on which AIO unit you have, you will either need this or this to make it work. Not sure if they are both the same or specific to certain units. I would get a hold of Corsair CS and see what they can do.
