- Jun 26, 2011
Hey,
I just checked my CPU-Z for the memory and was shocked to see this,
Type : DDR3-SDRAM PC3-10700 (667MHz) - [DDR3-1333]
Googled up and some say its because AMD RAMs are 'double-pumped' so 667MHz x 2 = 1333MHz
Not sure whats the real reason so thought I should ask you guyz.
Secondly, I was planning to upgrade and add another set of Corsair but this time instead of value RAM i was thinking of XMS3 4GB Dual Channel DDR3 1600Mhz which has a higher voltage and speed.
Could i run it w/ my present set of RAM? Would there be an issue?
Thanks for the help.
