- Thread Starter
- #21
I'm not really sure. Should be better than Gigabyte but It's hard to guarantee anything. If they made the same as in the last generation then it should be close to Unify and Unify runs at ~6600 max. Dominators 6200 run fine at XMP on Unify-X and overclock up to 6666 but it's the only Z690 MSI that I was testing and supposed to be the top MSI mobo ... still a bit disappointing. MSI doesn't support PMIC unlock on this RAM so you will be limited to ~1.43V. At least it doesn't work on my mobo but It's enough for 6400 CL32, sometimes more.
TristianX mentioned that F8e on the Master mobo is causing USB issues and is not fixing anything. I wasn't testing it but previous versions were not working with 6000+ kits and almost every BIOS update has info about improvements for 6000-6400 memory kits. For me, it works well only with ADATA/Samsung kit. I have Z690 Master in my gaming PC with ADATA 6000@6000 XMP as it doesn't work any higher.
