Sorry couldn't make it through the video. Not sure why these youtube people feel the need to over-act like William Shatner in Star Trek but it just seems common sense not to blow hot air on something meant to cool. Might be just me though.
You are still blowing warmer air over the second radiator in that situation. If I take two radiators one on top of the case as intake and one as intake on the front, both get cool air all the time. Why stack them and get warmer air on the second?What's the difference between stacking two rads and using one thicker rad? Let's say you stack two 30mm x 240mm rads with the first in intake configuration and the second in exhaust configuration. And you compare that to one 60mm x 240 rad with a push/pull setup (to keep the same number of fans in both scenarios). Theoretically, these two setups should cool the same since in both scenarios, the second 30mm of rad surface is getting cooled by the pre warmed air passing though the first 30mm of rad surface.
What makes more sense to me is to assume that two stacked radiators of a given thickness, if both are set to intake so as to get fresh air from outside with only a push or pull fan, will outperform one twice as thick radiator with push/pull fan setup. What I'm saying is that it makes sense to me that exposed, external radiator surface of a given area should cool better than a radiator of the same volume but less exposed, external surface area with the same amount of outside air passing through.
