- Sep 8, 2011
- Las Pinas, Philippines
i've bought a Corsair SP120 (High Performance Edition) Dual Pack. i've tried attaching it to a Cooler Master Hyper 212 . i've made it a push pull configuration. i've attached the first fan(push) to the main CPU fan 4 pin connection on the motherboard and the other one(pull) to the System fan 4 pin connection on the motherboard respectively. after booting i had an error that states "CPU FAN ERROR".. i've entered bios and it doesn't detect the fan on the main cpu 4 pin connection on the motherboard. i've tried swapping the other fan but i still got the error. what i did was attach a fan with a 4 pin power connection on the main cpu fan on the motherboard (the corsair fans is still attached on the hyper 212 and this fan is attached on the case) and i've attached the corsair fans on the other motherboard fan connections and it worked. does it really work that way?
this is the fan: http://www.corsair.com/cpu-cooling-...e-edition-high-static-pressure-120mm-fan.html
