Hi everyone, I recently bought two Corsair Vengeance 4GB x 2, 1600MHZ, each one ... I installed them on my mobo MSI 990XA-GD55, but after I enter to the BIOS, it shows that these rams are 1333Mhz ...
I Know, yesterday some one posted same problem as me, so its not that i'm too lazy to search, but instead of him, my pc doesn't freeze, it works normally but I would like to use the whole frecuency of my new RAM or I wouldn't have changed my last memories that were 1333mhz ...
This is what it shows:
When I put the DRAM Frecuency to 1600Mhz, and Adjusted DRAM Frecuency makes 1800mhz, and when I use CpuZ, it shows that DRAM FRecuency is 900Mhz
Then, if I change the DRAM Frecuency to AUTO, it makes 1333mhz, and right down the Adjusted DRAM Frecuency makes 1499, the cpu Z shows DRAM Frecuency is 750 Mhz ... (Don't look upside that shows DRAM Frec 1800mhz, that is from the previous image but I didnt restarted the pc so it shows that)
I can't find any XMB stuff on the BIOS ... Dunno how it works, but I hope that with the info I've given you guys, you can help me so I can enjoy these Rams Thanks for reading and thanks for answering with solutions ....
Pc Specifications:
Cpu: Amd Fx-6100 Six Core Processor
Motherboard: Msi 990XA-GD55 http://www.msi.com/product/mb/990XA-GD55.html
RAM: Corsair Vengeance 4GB x 2 = 8GB (1600mhz)
HDD: Western Digital 500GB 7200RPM
SO: Windows 7 Home Premium 64Bits
Power Supply: Tr2 600w ThermalTake
Pc Specifications:
