- Oct 28, 2017
...reasonably quick. I had a 6gb triple channel DDR3-1333 C9 ram less than 4 years and they started giving me error grief. I ended up eliminating 2 of 3 sticks and paired last remaining stick with different 1067 3gb(elpida) set. I ran them all on 1067 mhz speed because that last corsair stick wouldn't run stable on 1333 anymore, only 1067.
Now I know it's not recommended to mix different sticks together, but I did 24hr prime and memtest off boot cd and both checked out, until recently when I decided to fiddle around again with things in bios and increasing uncore caused black screen halt on boot until reset CMOS by removing battery. I narrowed it down to that last surviving corsair stick that finally died.
Is it just my bad luck or don't they last long enough? They wouldn't give me any tighter timings and I rarely went over rated speed, only to test sonetimes...my i7 can't run with fast ram anyways, so I usually ran it close to spec, voltage too.
Elpida OTOH is great! Overclocks to 1333 even 1400 no problem and timings are great(for its old age). 1067 sticks.
