- Jun 9, 2017
Friends,
In this topic:
http://www.overclockers.com/forums/showthread.php/783137-Water-wont-flow-through-system
I noticed Flat-G's reply to the original poster. Then I looked at the build he did, with a Caselabs SM8 case.
So I then looked at the Caselabs site and the prices they quote for the SM8 line put me into shock. The "Magnum SMA8" is priced at $639.95. Is this normal pricing for Caselabs products? I guess their "options" can drive the case cost up even more.
Off-topic side note: Flat-G, your build is awesome. Wow! You have machining skills that are amazing.
Thanks a ton
Bob
In this topic:
Thanks a ton
Bob
