- Jun 9, 2017
- Thread Starter
- #21
Thank you very much for the compliments! I originally mounted the radiator on top. That is, I slid the radiator under top of the case so that the fans pointed down at the motherboard. That looked wonderful, but there was no way I could get the 8 pin CPU power cable to plug into the motherboard connector with the radiator in that position. The cable is really fat and isn't very long. Maybe I need to look for a custom cable. Of the 5 cpu fan headers on that motherboard, header #1 is close to the 8 pin connector on the motherboard and plugging in the fan power would have been a problem too. So I moved the radiator to the right side. That seems to work. Of course, getting a drive cage in there will be fun now.The only thing I would do is either position that rad up top or add the fans in push configuration so you're not stressing out that tubing. Overall it looks great.
I will add one more fan after a bit more work.
I have another post coming up that will explain one more thing on my wish list, or my daydream list if you will.
Bob
