Hello everyone,
I just put together my first new system in about 10 years, back then I knew how to setup the bios, but all the settings nowdays throw me for a loop.
My relevant specs are as follows:
GIGABYTE GA-880GM-D2H (REV. 3.1) Motherboard
AMD Athlon FX-4170 Black Edition (is there even a non black?)
8gb Gskill Ripjaws DDR3-1600
I was hoping some kind and gentle soul could take the time and enlighten me as to exactly what my bios settings should be to get optimal performance out of this budget rig. I don't need to push the overclocking to it's limits I just want a good balance of stability and performance.
I followed Gskill's guide to setting up the ram for black edition cpus here:
http://www.gskill.us/forum/showthread.php?t=7688
but whenever I set the CPU NB frequency manually it won't post. Even if I set it to 2200 which is what the "auto" option sets it to. Other than CPU NB Freq I can change all of the other settings and it will boot fine.
All of my relevant bios options are as follows:
CPU OPTIONS
CPU Clock Ratio
CPU NorthBridge Freq.
Core Performance Boost
CPB Ratio
Turbo CPB
CPU Host Clock Control
CPU Frequency
PCIE Clock
HT Link Width
HT Link Freq
Set Memory Clock
Memory Clock
DRAM OPTIONS
DCTs Mode
DDR3 Timing Items
1T/2T Command Timing
CAS# latency
RAS to CAS R/W Delay
Row Precharge Time
Minimum RAS Active Time
TwTr Command Delay
Trfc0 for DIMM1
Trfc1 for DIMM2
Write Recovery Time
Precharge Time
Row Cycle Time
RAS to RAS Delay
Channel Interleaving
Bank Interleaving
DQS Training Control
Memclock tri-stating
VOLTAGE OPTIONS
DDR3 Voltage Control
NorthBridge Volt Control
SouthBridge Volt Control
CPU NB VID Control
CPU Voltage Control
Any advice is greatly appreciated,
Thank You.
CPU OPTIONS
CPU Clock Ratio
CPB Ratio
Turbo CPB
CPU Frequency
PCIE Clock
HT Link Width
HT Link Freq
Set Memory Clock
Memory Clock
DRAM OPTIONS
DCTs Mode
DDR3 Timing Items
CAS# latency
Row Precharge Time
TwTr Command Delay
Trfc0 for DIMM1
Trfc1 for DIMM2
Write Recovery Time
Precharge Time
Row Cycle Time
RAS to RAS Delay
Bank Interleaving
VOLTAGE OPTIONS
CPU NB VID Control
CPU Voltage Control
Thank You.
