The temp sensors are so inaccurate that one never really knows. My guess is that your CPU is at 55C load and maybe 40C idle. If it runs ok then I would not worry about it.
The 2 readings are only a couple degrees apart, so just figure your temp is in that range. With the Vcore you are running your load temps should not be in the 50,s with the idle temps you are getting. Your load temps should run mid to high 40,s.
