Hi all, I used a website to create a build for you and here it is: https://pcpartpicker.com/user/FlahRZ/saved/cFb3FT
Please disregard the Noctua cooler, I just needed to shut that site up about a cooler. They didn't list what I'm actually planning on installing, which is an EKWB block on one of my Titan V's, one on the Threadripper 1950x, and the Mobo itself. I decided not to cool the RAM because I heard it's more for aesthetics and the chips I got are eye-pleasing enough.
Couple of issues running through my mind -
I'm having some second thoughts about water cooling this thing, only because EK's configurator is calling for a 420 mm radiator, which would have to go on top. I spent a pretty penny on this case, which is supposed to be gigantic, but I think the largest rad it could fit is a 360 mm. The Specs for the case are mid-page here: https://www.newegg.com/Product/Product.aspx?Item=N82E16811854056 (the specs tab doesn't do the page I linked justice or I would have sent you right there.) So my first question is to anyone who is really experienced with water cooling - can I fit some combo of EKWB rads (https://www.ekwb.com/shop/radiators-fans) into here that will be aesthetically pleasing while also accomplishing their goals cooling-wise, and if so, what would you recommend?
My second question has to do with power consumption. I think that build page has this build in the mid 600's of wattage. But that page isn't taking into consideration water cooling or overclocking. I was planning to use a 1,000 watt titanium PSU from EVGA that I listed on it. I also have some 1,600 watt Titanium PSU's from EVGA here in y stock as well, though I really am not a fan of how the actual power cable connects to the unit (I've returned multiple units because it's like throwing a hotdog through a hallway on many of them...) and it seems like overkill. The unfortunate part is I don't have the 1,200 in my stock and I would really prefer not to spend more money if not absolutely necessary. What do you guys think? DO I have enough power with a 1,000 watt Titanium rated PSU?
Finally, and this would change everything- I have 4 water cooled Pascal Titan X's in my stock. I am so tempted to use a bridge to link them and install them for a total GPU mem of 48 gb. The Titan V is frustrating because you can't SLI it because they didn't build it with the capability for it. And installing a second Titan V without SLI seems like overkill because it's only going to be utilized in highly specialized things that I might do very rarely, please correct me if I'm wrong. But if I go the Titan X route (may have to switch mobo's) then I would end up with the ugliest PC ever because of how much space it would take up in radiators, correct? EK's configurator is telling me I need two 420's and a 240, to place on the top and sides, which would be a huge eyesore, IMO. What would you do if you were me? The Titan V is plenty powerful. Do you go for more if you have it in stock (but it might be ugly) or just stay put with something that's still going to do great for you?
Thank you all for your help! I really appreciate it -Rocky Zadok
PS FYI, the primary use of this is to create word docs and maybe some excel spreadsheets... jk, lol, seriously, it's for some gaming and also some deep learning exercises in Python.
