In short I'm wondering how effective lapping cpu's or heatsinks can be.
I'm just considering the process of actually a lapping a cpu and thinking that ok, I've seen it done on some forum or another a couple of times and it saved someone 2-5c after both cpu and heatsink is lapped or whatever, and all looks good etc.
But lets say I decide to lap a cpu for the first time (whereas someone posting on a forum may already have tried a couple of times), get what I need and go ahead and do it. Can I really guarentee that by lapping a cpu or a heatsink that i'll end up with an even surface?
We know machine cutting isn't perfectly accurate but assuming I was careful in doing this and measured the lapped surface using the chart regularly whilst working on it etc, how accurate is that likely to be?
Surely I could be 'just out' somewhere like a machine would be and end up with a just as inaccurately 'cut' surface?
Also, the majority of heatsinks out there now have polished surfaces. But I'm dubious as to if that means it's actually a good and accurate cut. Sure it shines, but does that prove it's an accurate cut and would it be as accurate as a properly lapped heatsink? In other words, should a 'polished base' heatsink be lapped anyway if one intends to lap?
Thanks for reading
Thanks for reading
