Advise please CPU cooler for FX-8230 (overclocked to 4GHz).
Motherboard - Asrock 970 Extreme4.
Asrock advises CPU cooler with a top-down blowing design
Case - Zalman Z9 +
Thanks!
Definitely true, I haven't considered that. I really dislike top-down coolers though, they not as efficient as tower designs for the CPU in general. I don't know of any popular top-down coolers though, might want to check out newegg for low profile coolers from reputable companies like Zalman. In addition, I'd recommend buying some of those small aluminum/copper heatsinks for those uncovered VRMs if you're going for heavier overclocks.They probably advise the top down to get more airflow over that weak VRM section.
Are you saying you already have the CPU OCd to 4GHz? Or you would like to?? I woyuld advise a more substantial MOBO if you haven't ordered it yet.
1) My #1 recommendation for air coolers would be the CM Hyper 212+. It's a beast of a cooler both size and efficiency, still one of the best air coolers for the money. Checking your case specs though, you will fit it with about a quarter of an inch or less between the top of the cooler and the side panel, so that will be a tight fit.
At least do yourself a favour and go for the 63xx series, you're not listening to what I'm saying. Your current motherboard isn't really up to the job of running any FX processor let alone the Octocore.
Case - Zalman Z9 +
Thanks!
Case - Zalman Z9 +
Thanks!
