Hello all. So I've had my computer working great for the past few months but then this weekend it took a dump. Was mid game in bf1 when my frames drop to 1 couldn't do anything so I immediately shut down my pc and upon reboot realized that my cpu was significantly overheating. So I take a look at my custom loop and see that the water isn't flowing as it should be. So I take out the pump and drain the pipes and test it with just tap water not connected to anything and it functioned just fine for the 1m or so I let it run with my hose flowing water into it. So I figure maybe it just needed to be cleaned out or soemthing. Anyways I put it back into my pc and its working fine putting the fluid back in for the most part. I get about 90% of the fluid back into my rig and then the same thing the pump stops pumping. Tried both connecting it to my pc for power and an external power supply so I know its not my power supply/mobo issue causing the loss of power. Now my confusion starts. I ordered new fluid thinking maybe it just needs to be changed out since its about a yr or two old (not 100% sure). Also thinking maybe the pump is just going bad and needs to be replaced but its just odd that it worked fine outside my rig with normal tap water. That or maybe theres a clog in one of my pipes thats causing the pump to shut down? This is my first custom loop pc so I'm very nooby with this type of thing. If you have any tips or suggestions I'd be happy to try anything. I'd like to avoid spending $130 for a new pump if I don't have to but will if ya'll think thats the cause of my issues.
Thanks in advance!
Thanks in advance!
