- Sep 10, 2012
hey guys first time poster here, and i was hoping i could get a few questions answered about some cooling options for my recently built modest gaming rig
first off, i have heard that some after market CPU coolers do not fit in the Raidmax smiliodon case. i have the Extreme Black edition if that makes a difference. Would the Arctic Cooling Freezer 7 Pro Rev. 2 fit in my case along with the side panel fan the case comes with? i believe the side panel fan is 80x80x25. and if it will not fit with the fan, are there other slimmer fans i could use with this cooler?
Smilodon: http://www.newegg.com/Product/Product.aspx?Item=N82E16811156078
Freezer 7: http://www.arctic.ac/en/p/cooling/cpu/4/freezer-7-pro-rev.-2.html?c=2181
Also, If that cooler will fit in my case will it block one of the RAM slots? My mobo is an Asrock 990fx Extreme4. according to the link above the only 2 ways to mount this cooler on an AMD mobo leaves all 4 memory slots open for use. i currently have 8gb (2 x 4gb) of Corsair Vengence but plan on upgrading to 16gb 94 x 4gb) soon so i would like all 4 RAM slots open for use if at all possible.
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157266
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
Also, i was thinking about getting a PCI slot case cooler as a secondary exhaust option to clear out the hot air under my Video card. Would this be worth it or is there a better option for removing said hot air?
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835888309
Video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125353
and i think that about wraps it up. Note that i am not dead set on buying any of these items and open to any suggestions that will improve air flow and cooling in my current rig.
Any help would be greatly aprreciated!
EDIT: forgot one thing, would the Freezer 7 even be that much better than the stock HSF that came with my AMD Phenom II x4 BE 965?
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
