Hey all,
I'm still having a problem getting my computer to post with my upgrade CPU. I originally tried the Phenom II X4 945, and AMD said to send it in. They sent me a Phenom II X4 925 (I assume they were out of 945's), and same problem.
Under msinfo32, I'm seeing: Revision 1103, 4/22/2010. I updated that myself with a thumb drive but I'm not 100% sure I did it correctly. The update went through and the PC restarted as a result, but I'm still skeptical.
I've reset CMOS via the pin cover thing. I've also remove the batter and reset CMOS at the same time for a few minutes. My old CPU works just fine on this board, and the new CPU is on the support list. This is the third CPU I've received from AMD so I'm pretty sure it's not the CPU.
Although this CPU is on the support list, I feel that either it is not compatible or it is a software issue. Any ideas before I take this into a computer repair shop? Thanks!
