I have touched the top of my WW and it isnt even warm, so I cant see a copper top making more than a degree or two difference. Also just looking at how the poly top is fitted to the copper base, its hard to see how it can warp/bow.
There comes a point where you reach a certain amount of pressure at which time it doesnt matter how much more you clamp it down. It wont help you and just risk damaging something.
yeah, im not sure how the poly top can warp. maybe you feel more secure with the copper top so you tightened it more? also, the copper top looks thicker, so wouldn't that mean that if you tightened the knobs down to the same level, the springs would be compressed more?
no, but in theory, you can get the same amount of pressure easily with both tops. i was just thinking that if he was judging how compressed it was by how much of the screw was sticking out, then it would be more force with the copper top cause its thicker
that other thread mentions warping, but it is explained that the warping is corrected by the plate above the channels i still don't understand how if in both cases, the springs where tightened exaclty the same, it would result in 6-8 degrees difference. you said that with both tops, you can fully compress the springs, but then on the copper top when you were able to fully compress the springs, which contradicts what you said. im sorry, i'm (we're?) just having trouble with your logic and trying to interprete your results.
zip22 said:its just hard for me to understand how the polycarbonate can warp and produce negative effects like that, but it definately seems like you did a lot of testing.
How long have you had your WW from Dtek? I hope mine will lastMilkman said:
I will post some with sadness
Milkman said:Well just got my top from Logicooling, chose the machine finished top and it is so sweet back up on water and over 2700 again, I am so happy I have to wipe tears from my eye anyway this is the way to go, great job Neomosis!!
JFettig said:Those arcs on the top are from the machine when it cut them. I dont understand what you mean by round candy. Milkman I would like to see pictures! same with you H2OLinux.
Jon
