I have an amd 9370 with a closed loop setup (Corsair Hydro Series H100i GTX). Idle temps stay low, between 14-24C, but this is because I have it in energy saving mode. If OC, it still heats up pretty quick (peak of 85C) and the PC will power down within a couple seconds of starting a game. This is likely on me, since I have my PC setup in a closet (there is no door on the closet and it is placed in there in order to have it connected to my living room TV), so ventilation is pretty crappy despite all of the fans in the case (Cooler Master HAF XB II EVO). So, finally to my question. I am considering doing an open loop water cooling system on it and I am just wondering if you know if anyone else has tried what I am considering.
So, I would prefer to keep my PC in the current location and because of this I am considering using copper tubing through the floor and placing a radiator in the crawlspace or copper tubing runs buried a couple inches in the dirt/crawlspace. Since the temp in the crawlspace is always cooler than the temp in the home, I think that this would cool my cpu much more than having an internal open loop setup. This would require flexible quick connect/disconnect to the PC, a stronger pump (because of the amount of fluid that will be in the tubes), and I would have to figure out a way to drain and fill the system. So, has anybody tried this? Does it seem practical/doable? Also, does anybody have any ideas for draining the system?
When I worked at the dealership, the flush machines we used for transmissions and coolant flushes had quick connects that pushed new fluid in while it sucked the old fluid out. This would just require a separate pump assembly and lines for me to connect to it once a year or so, but this is one option that I was considering....besides the obvious one (me dragging my *** into the crawlspace every time to properly drain it).
