Running 8 fans so its hard to keep all the wiring under control, was much worse earlier.
And alright, thank you , would you recommend reference or a company version?
280x=7870 270x=7850 so no big change there. If your looking for better card it'll have to be a 290 or 290x 290=7970 while the 290x is latest.
On the topic of xfire while it'll be better for now looking at your cramped case I cant help but wonder if you'll run into heat issues.
The 280X is a 7970... Not sure where you got your info. The 270x is a rebranded 7870 ghz.
Either way I always suggest a single card upgrade. Grab a 290 with one of the new custom coolers and be done with it IMO. Solid upgrade. Just make sure it's not a reference design lol
Don't know what's all the fuzz around the ref design: one of my 290's is unlocked to a 290x. It runs perfectly@1175/1500/+150mV, and temp never goes above 85°C/80% fan, with a 24°C ambient.
@90°C, the fan runs@around 70%.
@stock clocks, it sqtays around 30/40% on load with 80°C max.
