- Dec 22, 2012
- Southern California USA
thanks
Thanks for reminding me Dr.
Oh yeah, I was sure the chips were supported but it may take a BIOS update for them to work as in once you take the board out of the box new. The board you get may have sat on a shelf in a warehouse for sometime and "Missed" the latest BIOS update.
@ Erixx: No prob to do with a regular AM3/AM3+ chip.
If the board works with your 9xxx series chip, you won't have to do any of the following but if not, here's what you do to get that sorted out.
First place a regular AM3 or AM3+ chip into the board, any chip for those sockets will do, even a Sempron.
Then download the newest BIOS file onto a USB flashdrive, then do the update with the utility in the board's BIOS. Next, confirm the board took the flash by letting it reboot once, then shut it down and turn off the powersupply with it's switch located on the back of the unit or simply unplug the PC itself from the electrical outlet. Next, remove the "Old" chip and set the new chip in with the heatsink/fan you want to use and be sure to use a good quality TIM or thermal grease with it (TIM and thermal grease are the same exact thing) - That's all there should be to it.
After you do all of that, turn the powersupply back on/plug the PC's cord back into the outlet, start the system, configure things like you want in the BIOS, save your settings and enjoy your new chip from there.
