Crysis 2 : Failed to Initialize
Cruzaders
Hello, this is my very first thread, hwgo:
I downloaded Crysis 2 yday and installed, dx11, very high resolution pack and 1.9big pack.
When i try to run "Crysis2" i receive a popup:
"Failed to initialize the GameStartup Interface!"
and when i click OK nothing happens.
This is the log file:
HTML:
BackupNameAttachment=" Build(0) 14 Mar 12 (00 57 56)"  -- used by backup system
Log Started at 03/14/12 00:57:56
Running 32 bit version
Executable: C:\Program Files (x86)\Electronic Arts\Crytek\Crysis 2\bin32\Crysis2.exe
FileVersion: 1.9.0.0
ProductVersion: 1.9.0.0
Using STLport C++ Standard Library implementation
Added MOD directory <engine> to CryPak
Executable Command Line: "C:\Program Files (x86)\Electronic Arts\Crytek\Crysis 2\bin32\Crysis2.exe"
Total number of logical processors: 8
Number of available logical processors: 8
Total number of system cores: 4
Number of cores available to process: 4
Processor 0:
  CPU: Intel         Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
  Family: 6, Model: 10, Stepping: 7
  FPU: On-Chip
  CPU Speed (estimated): 3502.1 MHz
  MMX: not present
  SSE: present
  3DNow!: not present
  Serial number not present or disabled
Processor 1:
  FPU: On-Chip
  MMX: not present
  SSE: present
  3DNow!: not present
Processor 2:
  FPU: On-Chip
  MMX: not present
  SSE: present
  3DNow!: not present
Processor 3:
  FPU: On-Chip
  MMX: not present
  SSE: present
  3DNow!: not present
[Warning] Unknown command: sys_game_folder
[Warning] Unknown command: sys_dll_game
[Warning] Unknown command: sys_user_folder
[Warning] Unknown command: r_ShaderCompilerServer
[Warning] Unknown command: log_IncludeTime
[Warning] Unknown command: log_verbosity
[Warning] Unknown command: sys_PakLogInvalidFileAccess
[Warning] Unknown command: sys_float_exceptions
[Error] Error: ConsoleVariableGroup 'sys_spec_physics' key 'p_max_substeps' is not missing in default
Windows 7 64 bit SP 1 (build 6.1.7601)
System language: English
Windows Directory: "C:\Windows"
Prerequisites...
* Installation of KB940105 hotfix required: no! (either not needed or already installed)
Local time is 00:57:57 03/14/12, system running for 510 minutes
16367MB physical memory installed, 13006MB available, 4095MB virtual memory installed, 20 percent of memory in use
PageFile usage: 51MB, Working Set: 37MB, Peak PageFile usage: 52MB,
Current display mode is 1360x768x32, (Unknown graphics card)
IBM enhanced (101/102-key) keyboard and 3+ button mouse installed
Stream Engine Initialization
GameName: Crysis 2 (TM)
BuildTime: Jun 16 2011 19:55:30
Font initialization
Physics initialization
Sound initialization
<Sound> Initializing AudioDevice now!
<Sound> Initialize FMOD with dynamic memory callbacks
<Sound> Starting to initialize Windows Audio Session API output!
<Sound> Drivers found: 2
<Sound> Available drivers:
	1.	Speakers (Realtek High Definition Audio)
	2.	Realtek Digital Output (Realtek High Definition Audio)
<Sound> Using speaker mode: FMOD_SPEAKERMODE_STEREO
<Sound> Initializing FMOD-EX now!
<Sound> Initialized FMOD-EX
<Sound> Available record drivers: 0 Mic in at front panel (Pink) (Realtek High Definition Audio) !
<Sound> Record config is set to autodetect using record driver 0
<Sound> Using FMOD version: 00043307 and internal 00043307!
<Sound> Initializing SoundSystem now!
Renderer initialization
System Shutdown
[Error] Runaway thread
Closing PAK file: gamecrysis2\animations.pak
Closing PAK file: gamecrysis2\gamedata.pak
Closing PAK file: gamecrysis2\music.pak
Closing PAK file: gamecrysis2\objects.pak
Closing PAK file: gamecrysis2\objectsls.pak
Closing PAK file: gamecrysis2\scripts.pak
Closing PAK file: gamecrysis2\sounds.pak
Closing PAK file: gamecrysis2\textures.pak
Closing PAK file: gamecrysis2\videos.pak
Closing PAK file: engine\engine.pak
Closing PAK file: engine\shadercache.pak
Closing PAK file: engine\shadercachestartup.pak
Closing PAK file: engine\shaders.pak
Closing PAK file: engine\shadersbin.pak
And this is my pc config:
http://valid.canardpc.com/show_oc.php?id=2296030
Can anyone help me?
Pretty sure i'm.
Program files> Eletronic Arts> Crytek > Crysis2> Bin32> Crysis2.exe
And there is another one called "Crysis2launcher.exe" but also reports the same error.
I've been searching on google, and no way to put it work. T-T
This is what my trip to google yielded:
Ok, I uninstalled Crysis 2, I uninstalled Origin, Re-booted and deleted the empty folders. I installed Crysis 2 and applied the patch myself. I did not let the automated download go through and My Crysis 2 is back up and running. I am afraid to do the high res and dx11 downloads now that I have my game back up and running. LOL But what the heck, I can always start over again. Hope this helps some others with this issue.
Have you tried to launch through Origins?
Hey! I found what was wrong.
I just reinstalled the game and started. Worked normaly. Then installed patch by patch, manually. Now its working fine. Thank u!!
