- May 15, 2006
Hello all,
I would like to start this post with the following comment, as it is extremely important to this thread. I have no experience with web coding, but I do know a bit of C++. The syntax seems to be similar to PHP and I can see what options/files do by modifying them and observing the result. Obviously, I'm not stupid when it comes to computers, but you may need to spell it out or ask very specific questions.
I've been assigned the task of creating and administrating a website for our WoW guild. After much discussion with some others in the group, we decided on Joomla 1.5 as a front page and PHPbb forum as the forum. Both these systems work exactly like we want, so are not willing to change either. I've stumbled through modifying the themes and integrating components and I think I have been doing pretty good thus far. I've been working on this specific issue for a few weeks and have stopped making progress.
The main goal is to have the front page match the forum, in terms of looks. How we reach this goal is irrelevant. If it would be easier to simply add the "top" portion of the front page into the PHPbb code itself, I have no issue doing this. Whatever gets it done.
Website front page:
http://enigmadw.com
Forum integration page:
http://enigmadw.com/index.php?option=com_jfusion&Itemid=59
Direct forum link (NO integration):
http://enigmadw.com/forum
Joomla base theme: tx_gravity
PHPbb base theme: melankolia
Now, onto the problem.
Starting with an example. Here is a broken post and here is the working version. The only difference is the integration. The problem is that the author box is only as wide as the longest word in the table instead of the specified 180px that it should be. Using Firebug, it reports the width of the broken table to be 180px wide, so I'm a bit confused as to what is going on. I was looking at the source code for the page and noticed that there are multiple calls to different style sheets. I've done a little bit of reading on how these work and it seems that the latter one always takes precedence over the first unless it is set as "preferred". I've also fixed an issue where two "div" objects had the same name and cause some graphical errors on the page, renaming one of them fixed it. I attempted to apply that to the current situation, but there is nothing that matches between the CSS sheets. I know that the table for posting calls three 'variables' (not the correct word) from the CSS sheet; tablebg, row1 and row2. The specific one that is displaying incorrectly seems to be "row2".
I've been changing files all morning attempting to fix the problem, but I can't.
Ideas? Let me know if you need more information.
EDIT: I'm thinking it would be easier to add the menu system to the top of the forum and just ignore "integrating" the two websites. That would fix a lot of problems, including some that I haven't mentioned here. How would I go about doing this? Do I just need to find the PHP code that creates/calls the menu system and simply drop it (modifying paths where necessary) in the PHPbb code?
Website front page:
http://enigmadw.com
