yah i think i only have 32 sp's on my 9500gt. :/
Seti@home just updated their Tasks section under each computer, and it now has Run Time in (sec) in addition to CPU time (sec). This will help with our calculations of RAC of Video cards...no more guessing!
As an update. I have a rig that's a dedicated CUDA rig. I run Rosetta on the CPU just for fun (it's just a single core 3500+).
GTX260 192sp 684/1440/1053 core/shader/memory. RAC has bounced up and down around 6000K for the last 4 days. I'm going to switch up the cards now. Will update when that's ready.
You don't use your CPU for crunching?Hmm. I know you've switched cards to the 95GT, but were you running the CUDA2.3 dlls on your GTX260 192? 6k seems a little low. I'd be guessing around 8k to maybe 9k RAC with that card.. My GTX260 216 @ 701/1509/1045 [c/s/m] on a single core 3000+ is pushing 11500 RAC (still hasn't stabilised yet). The even with 24 fewer shaders and slightly lower clocks, I wouldn't think it would drop the RAC by 5k+.
Only thing I can think of is either using the CUDA2.2 dlls, or the fact that my CPU is dedicated to feeding the GPU, whereas yours is running Rosetta.
Interesting indeed!
I wouldn't think there would be much difference between running SETI on the CPU and running Rosetta on the CPU - at least not as far as the GPU goes. It would add 500-600 RAC to the rig ...
Interesting indeed!
Glad for the explanation - Thanks!Sadly, I don't run SETI on the CPU. If I do, it lowers RAC by ~2K rac. From what I've gathered from the SETI forums, and what little I know of hardware, heres a possible reason.
The GPU needs to be constantly fed information to crunch (can't simply load the whole ap and WU into the GPU and run it natively - CUDA's not that developed... yet), and this can be seen in windows Task Mangler as an intermittent 13-20% CPU spike every second or so. If you run CPUSETI as well as GPU, the two apps then fight for CPU cycles (as both are defaulted to low prority). In doing this, CPUSETI uses ~80% of the CPU and the other 20% is the CUDA app.. however, everytime the CUDA app needs to feed the GPU, it has to flush the CPU pipeline of the CPUSETI threads, start the GPU thread, then when that terminates, reload the CPUSETI thread.. rinse/repeat.
The constant having to flush/load the different CPU and GPU threads causes a massive decrease in RAC (as the GPU is -vastly- quicker than CPU), particularly on single core CPUs. For multi-core, it's less of an issue because you have more cores to play with, the flushing/loading of threads doesn't impact as much, but it still does impact.
As an example, rigs owned by Vyper and Sutaru Tsureku on the SETI forums are dedicated GPU crunchers, and they've dramatically increased their RACs by stopping CPU crunching. As a rule of thumb, for every GPU you have in your rig, keep 1 physical CPU core deciated to feeding it, and you'll increase production quite a lot. (Note that I said physical core, as if you choose to simply leave a logical core free [as in the P4/i7 family], you run into the same flush/load problem as stated above, just not as badly as you'd see on a single core).
Hope this helps! sorry for the long-winded explanation
I have been watching Careface closely (as we are neck and neck) and I was amazed at his 260gtx performance. Mine was only at 7,500 rac max with CPU crunching enabled. I just now disabled my CPU crunching and am seeing if I can duplicate his efforts! Though my clocks are slightly lower.
Well, I had thought the RAC had stabilized seeing it bounced up and down for the last 4 days. If I look at the DAC on boincstats, for the last week, it's DAC was 6851. When I get home tonight, I'll put the GTX260 192 back in with the CPU idle and see how that performs over the next week or so. Yes, I was using the 2.3dll's.
Now that you mention it though, Since I added the Athlon II X4 to my rig 1 (too lazy to update my sig) instead of the Kuma that was in there, my RAC has jumped dramatically. More than I would have expected from going from 2 to 4 cores on the CPU. It might be that the extra CPU core, plus running 1 less GPU has resulted in greater efficiency of the remaining GPU. Very interesting indeed. I think I might be getting a RAC bump pretty soon.
This is a fairly dumb question but how can you tell if your gpu is crunching? I put the 8400GS back in my T7200 computer about a week ago and BOINC sees it, but GPUZ is saying the temperature for the card doesn't change whether BOINC is running or not. The computer hadn't been crunching for a while so the RAC was still climbing when I added the card.
setiathome_enhanced 6.08 (cuda)
Look under the tasks in the Boinc Manager, GPU units will be labeledIf there are no tasks there, then you may need to re-optimize, and make sure you select CUDA in the optimization wizard. By default it is not checked.Code:setiathome_enhanced 6.08 (cuda)
