crankyslap
- Aug 19, 2012
My card (
) is sometimes running too hot, but what bothers me even more is the amount of noise it makes with the stock cooler... if you're wondering just how bad it is;
I've sort of gotten used to it, but it's still very annoying so it's time to take action. The "Accelero Xtreme" I had my eye on has been discontinued, and besides watercooling there doesn't seem to be a real solution. Since I'm strapped for cash, it looks like I have to get creative.
But I'm new to this, so I'm looking for help.
At first, I found this:
Does this really work? And if so, how do I do it?
If I understand correctly:
-Cut two holes above the heatsinks
-Place two fans on it
But how do the fans hold? And I don't have any fan connections left on my mobo, is there something like a cord that you plug in the mobo, that on the other end provices 3 to 5 (or so) extra fan-connection-openings? (My explenations ROCK!)
Second, I found a guy doing this: but I'm not exactly sure what's going on there. is that like.. a fan with two heatsinks that just so happen to be placed exactly right to accomodate my cards GPU placements?
And then thirdly, I found this: http://www.overclock.net/t/429656/official-ati-radeon-hd4850x2-thread/290#post_5389206 which are 25 euros a pop. That's doable.
Looking forward to any info you guys have to offer on this!
