- Mar 19, 2009
- Minneapolis
i see your an nVidia fan
how did you get that UV thing on your PSU though? that looks cool.
GTX280, so you joined after all. Glad to see you here.
WELCOME TO THE FORUMS!!
I test fit a slim line slot loading DVD player today. I still need to clean up the edges and then really make sure the edges align before I color match everything, but so far so good. I would have cut just a slot for the Drive out of the top and a spot for the button, but I didnt want to risk scratching discs. As a warning for those trying this mod, while cutting the steel is easy, the case IS made under tension. As soon as I cut the notch out (while saving as much steel as physically possible) the case popped ever so slightly out of square. I'll be adding a few rivets to it tomorrow.
I was worried I was going to run out of 5" bays.
I don't see any modding per say I do see a sweet paint job need some pic's of the inside of the case as well . Falls short of a mod job to me as it is still all very much stock except for the paint .
As the headline says, Custom modding and "Painting Only"
"Custom modding denotes some one has done some changes other than just painting IMHO this is custom modding "
lol and im saying he did do somethin more then painting it haha
