another question.. is it possible to have the reservoir laying on it's side rather than vertically?.. i'd love to be able to mount it at the bottom of the case, just above the illuminated "nzxt" symbol on the psu shroud..
This config will flow over the motherboard, if anything is sticking up it will not fit, if the board has nothing sticking up at the very top it may fit
now i'm even considering dual 360mm radiators.. if i do that, i'm sure i can have an ultra quiet system thats nice and cool.. and will look bad ***.. now it's just a matter of saving up the cash for it lol.. thanks for your input guys.. it's much appreciated
I would advise against that, as the force of gravity on the column of water is needed to keep the pump primed at startup and when filling the loop.
Yes, it will overlap a tiny bit.
No, it won't hit. The 990FX Killer doesn't have anything in the way.
Not quite, but i'll let Newton sleep on this one ....
But, as long as you can assure enough water "above" the pump, it works. There is another problem though with horzontal orientation: your system MUST be completely filled, if you've got any air "trapped" in the reservoir it is very likely going to be sucked into the pump.
Also, i would like that more people would give the purpose of a reservoir some tought.
A reservoir mainly serves 4 purposes:
1. Air trap
2. Expansion vat (when the liquid warms up, it expands and compresses the air trapped)
3. have a reserve of liquid so you dont have to top up every 2 days
4. "easy filling"
Now, how can the air trap work if it is NOT at the highest point in the loop?
Think about that for a minute.
What do you think that water in a tube is? A column.
The pump is primed due to pressure. Pressure is a function of density, gravity, and change in height.
Density of water is (basically, for this case) constant. Gravity, constant.
So, we change the height of the water column.
I recommended standing the reservoir vertically to achieve this height change for priming the pump.
Thanks Mr. Newton.
Fundamentally true.
And while keeping the res-tube upright is easier, it is not required AS LONG as you have A column of liquid above the pump to gravity feed/ease the priming at startup. In this (and a lot of other cases) the column above the pump does not consists out of the liquid in the res alone... The column consist of ALL liquid above the pump, thus also the liquid which should already be in the radiator & hoses.
And.. there is also something like pump suction.. but lets not get into that
(The story changes when you are still in the filling up fase thou)
Look, you ARE right, its just not always as clear cut as it seems, that's all.
