- Feb 13, 2005
- Thread Starter
- #21
Ok. I decided to do more reading. I found this article in spcr by burcakb.
Now I don't know what all that means. I wish I could find a article to help me both understand and calculate like he did (anyone got a link?? would much appreciate it ). I'm still wondering how that efficiency thing works. if he caculated to 22.2a (if I read it right) and the psu gives 24a with 80% efficiency doesn't that become 19.2a ?? or does it not work that way?? (oh well, anybody got a link where i can read and learn, much appreciated). Been reading alot (so much I don't know ).
Anyways, after all that got a new psu looking I'm looking at.
I need it to handle :
fx-57- oced
2gb memory
2 74gb raptors
2 6800 ultra extremes- maybe oced
4 - 120 mm fans
dvd-rw
(even if I don't get that at beginning, I want something that can handle it- I don't want to waste money and keep changing psu's)
Will this handle it ?? I'm basing it off what that guy wrote. It has total of 29a for the 12v, not sure if that will be enough though. Whats the minimum?
http://www.newegg.com/app/ViewProductDesc.asp?description=17-151-023&depa=0
If this works (is enough power), that would be perfect- everything i want. But guessing too good to be true.
Here's the whole article:
http://forums.silentpcreview.com/viewtopic.php?t=19778&postdays=0&postorder=asc&start=0
Is it wrong or good info??
Shall we try and put a more realistic and informed judgement into this argument?
The DFI boards are marketed as overclocking boards. They have the ability to go to EXTREME overclocks - provided with monster voltages & airflows.
Now, as this is SilentPCReview, while we may all wish for a little overclock, we don't usually want it to the point where noise becomes a serious issue.
The most important criteria these days when choosing a PSU is the 12V feed power, not the total wattage. The 3.3V + 5V rails are mostly around the same ballpark in modern PSUs so the differentiating factor is the power delivered on the 12V line.
A Winchester Athlon64 operates on 1.4V Vcore with a top cited TDP of 67W. That means the top power draw without overclocking will be 5.6A on the 12V rail. Let's overclock some. 25% clock increase at a cost of increasing core voltage to 1.8V. I think we can agree that this puts a kind of worst case scenario for heat & power. Since power draw is related to the SQUARE of core voltage, 1.8^2 / 1.4^2 = 65% increase. Add the %25 clock increase too, that gives you a 100% increase in power, resulting in 134W. We can safely assume that we're pushing the limits of possible quiet cooling. 134W required 11.2A on the 12V rail.
Lets look at nate's gear:
The 6600GT I'm guessing will drain around 2.5A. The seagate will require around 2A at spinup, less afterwards, say another 2 for the DVDRW. That's a total of what? 6.5A. OK, let's say, he goes for extreme overclock on the 6600GT and adds another hdd and another DVD. That'd make 3A for the 6600GT, 4A for the hdds, 4A for the optical drives (this is really a worst case scenario. Thanks to cascaded spinup, the actual power draw will probably be at least 2A less) for a total of 11A.
So a PSU supporting 12A on each rail or a total of 24A on a single 12V rail will be enough to get you very serious overclocks on both the CPU and the VGA. The Seasonic SS 400W is 22A on the 12V rail so it's borderline (I think if you tried running the system with the 400W, it still would run stable but we're really being extra extra safe here) so a Seasonic 460W would be more than enough for you.
There's your proof that a 500W is overkill. Please note that the power requirements for the CPU overclock (a 100% increase) is pretty much a worst-case scenario and you really wouldn't be able to exhaust so much heat quietly anyway. I'd even bet money that if you overclocked a little less (even the same overclock at a slightly less voltage, say 1.7A) that system you specified (plus an extra hdd or two even) could be run with a 400W seasonic in a properly ventilated case.
For the record, despite my patience, I'm also getting fed up with newcomers who carry the "I don't want to learn anything, just answer my question" attitude. This is not directed at any one person but a general vent of my frustration.
fx-57- oced
2gb memory
2 74gb raptors
4 - 120 mm fans
dvd-rw
