- Jan 22, 2003
- Durham, NC
If I hooked up my 1300 to that much tubing it would probably cry. Or am I underestimating my pump?
aldamon said:If I hooked up my 1300 to that much tubing it would probably cry. Or am I underestimating my pump?
Neco said:I never understood the whole temp competition anyway.. Its like " dude my **** is bigger than yours" on the internet or something.
I personally feel if your full load temps at under 50 and you are overclocking with water cooling, then you have done a good job.
With water the performance is not in the lowest temp, like was pointed out, its the better delta. At least thats how I feel. I'd like to see a HSF go from 29C idle to only 33C full load in a regular environment.
Then you have to factor in how everyone is taking temps (diode ? socket ? how reliable ?) its just not worth it.
If your PC runs and is stable, and you don't smell anything burning. You have done a good job. End of story.
Thats a nice setup by the way.
1-Man-Army said:nice job was wondering how much volts are u putting into that proc? while @ 2.35ghz
