I think my mobile Athlon XP 2600+ has been damaged by OCing. When I first got it I could run at 2.66ghz at 1.95v, but I ran it at 2.53ghz at 1.8v b/c I only have aircooling. My temps were usually 40-50C, and never went above 58C even with the heat cranked up in my room. I ran it that way for about 6 months.
Over the past few weeks the maximum vcore I can run at has dropped to 1.65v (even at stock speeds). The load temp at 2ghz and 1.65v is now 47C, so I don't think it's a heat problem. If I try to run at 1.675v or higher it either doesn't boot, or shuts off with a two tone warning siren seconds after starting a prime test. I put copper heatsinks on my MOSFETs and PLLs and replaced the stock northbridge HSF w/ an NB1C. I've also tried pushing the temp sensor under the CPU up. None of that helps. If I push the temp sensor all the way down, it won't even boot.
At first I thought that my motherboard was at fault, but I put in an old Duron 1300 and it primes at the stock voltage of 1.75. Has anyone else had something like this happen?
my specs
Abit NF7-S v2.0
Thermalright SP97 heatsink (w/ AS5)
92MM Vantec Tornado at 7v
2x512MB PC2100
Fortron 530watt PS
my specs
Abit NF7-S v2.0
2x512MB PC2100
Fortron 530watt PS
