- Nov 1, 2001
- New Iberia, LA
I have been using a DD MC-TDX for the last month or 2 on one of my watercooled systems and frankly, thought it was leaving some cooling performance on the table compared to The Apogee GTZ, which I am using on another system. So, I decided to test my theory out and purchased another GTZ for this test. The system this will be tested on is a Seti cruncher (which means no decent graphics card, just something to put a picture on the monitor) and has been a good stable machine. The components of the machine are as follows:
The cooling system consists of the following components:
The 2 waterblocks being tested are:
I am not going to get into which mounting system is best because that is personal preference and both require you to remove the mobo from the case for the initial mount and both do secure the processor well. But I did remount the MC-TDX 4-5 times looking for a better mount before deciding to do this comparison. The mount I am testing with was the best one I had while working with the MC-TDX. The GTZ was tested with the first mount I made on this motherboard as I was sure I got an excellent mount when I fired it up.
For stress and heat testing I am using OCCT version 2.0.1 and running the default 1 hour test. Room temperature was controlled at 20-20.5 C while testing both blocks.
First up was the MC-TDX, since it was already mounted and properly seated. OCCT ran successfully with the MC-TDX and here are the temperature results of all 4 cores:
- Silverstone TJ06-B case
- BFG ES800 psu
- Asus P5Q Pro motherboard, bios version 1406
- 2 X 1 GB Crucial DDR2-800 Ballistix (single sided), running at 400 MHz with 4-4-4-12-2T timings
- G0 stepping Q6600, 1.25v VID. Running at 400 X 9 with 1.42-1.43v vcore. This processor has not been lapped, but has shown remarkable consistancy between all the cores with whatever I have mounted on it
- ATI Radeon X1600 PCI-e video card
- 2.5" Seagate 100 gig 7200 rpm hard drive salvaged from my laptop
- 12X SATA DVD-RW
- Swiftech MCR320-QP Res (built in reservoir) radiator
- Swiftech Radbox Revision 1 (the metal one)
- 3 X Petra's Yate Loon D12SM fans
- Swiftech MCP355 (Laing DDC 3.2) with XSPC top, 1/2" barbs
- 1/2" Tygon Silver Antimicrobial Tubing throughout the loop
- Barbs used are the 1/2" Swiftech High Flow metal and the 1/2" EK Fatboy barbs in the loop
- Arctic Cooling MX-2 used for TIM material
- Swiftech Apogee GTZ, totally stock with 1/2" Swiftech High Flow metal barbs (included with the GTZ)
- Danger Den MC-TDX. equipped with the brass top and stainless steel universal mounting bracket with 1/2" Fatboy barbs (included with the MC-TDX). The mounting kit has been modified with a TR LGA775 backplate to spread mounting pressure across a wider area than the 4 individual stud approach that DD sells with the waterblock. Other than using a backplate to mount the studs instead of individually mounting each stud to the corresponding hole in the mobo, the mounting system is totally stock, using the included mounting studs, washers, springs and thumb nuts to mount the block.
