- Feb 11, 2011
Hello!
I have an older rig that I have recently tried to upgrade the memory on.
Here are my old specs:
**2GB DDR2 667 Single Ch 64 bit **
Gigabyte GA-MA69VM-S2
AMD 64 X2 5600+ 2.81GZ
Radeon HD 4670
Win XP SP3
Since my older GA board supports up to 16gb DDR2 max 800mhz in Dual Channel, I found a special for 4 X 1 GB sticks of Crucial DDR2 PC2 6400's online and ordered them.
Well, I have been having a hell of a time installing these 4 sticks. Not only will the board NOT take ANY sticks in the correctly colored dual channel slots, but I have made sure (by sticking each set of new 800's in to my current slots that work) that all the memory I got from Crucial are good.
So, my mobo seems to only want to read/accept these sticks in 1/3 slots, and will NOT boot with them in any combintation of sticks being put into 2/4 slots. My dual channel slots are obviously 1/2 and 3/4.. and the mobo's manual says that dual channel should be applied 1/2 and 3/4.. it also says it definitely will accept all 4 sticks. (I've tried 1/2/3.. 1/2/4...etc.. and when I DO put only 3 sticks in, it will boot, but won't get past the initial Memory Check on the first black screen, and stalls!.. this is ONLY with 3 sticks in, as I merely get the POST beeps if I put 4 in!)
I'm at a loss here.
I was using Award Bios F4 and I had heard it could be a BIOS issue, so I used @BioS to get the newest update which was F9. Everything loaded perfectly well and still NO GO on these. I went into BIOS to try to manually set the timing, but with no avail.
The current timing on the sticks (2 X 1GB of the new 800z) that CPUID reads is:
JEDEC #3
400mhz 6-6-6-18-24 @ 1.8v
I had also heard that it could be a voltage issue? But in F9 I haven't seen any place to adjust the voltage higher so it will be able to use all 4 DIMM slots. I used the "secret" menu CTRL F1 and still no dice.
Am I missing something!? I know this is probably a stupid question and I COULD suck it up and buy 2x2 GB of the 800z, but even then it seems it wouldn't be able to read in Dual Channel.
UGH!
Any help? Thanks!
James
Radeon HD 4670
Win XP SP3
I'm at a loss here.
JEDEC #3
UGH!
Any help? Thanks!
James
