- Jan 17, 2012
- Texas
Ok, so I have a choice. I can go with either an X48 DDR3 solution or an X38 DDR2 solution. The northbridge minor FSB capablity difference does not matter as the CPU is going to be a QX9650 either way and neither board can do over 1333 Mhz RAM with that CPU. The catch is that with the X38 board I'm going to possibly be able to use dual Radeon HD 4890s in CrossFireX but with the X48 DDR3 board I only can use 1 4890(board has Dell Hell OEM S**t about the GPUs) If I sacrifice DDR3 for the better GPU horsepower will it be worth it? Oh also the X38 board is identical to the X48 other than the RAM slots, a slightly different PCI slot configuration and it has more SATA ports, a 39-pin floppy and some SAS ports. Note: Please don't just tell me to scrap the lot and get something better/newer because this is an experimental project to try to figure out why dell is so s***ty.
