Aaaand I'm lost.
With the start of dual channel on the PCs they used ganged. Example dual channel, two memory channels striping 64bit of data across 128bit for twice the speed.arrange (electrical devices or machines) together to work in coordination.
depends on the test... both similar. Lots of testing if you look. It makes sense you cant pick anything as, again, its an AMD term and functionality....you have an intel x58 based system.Which one is faster? I'm running twin chanel, but I can't pick either option
Raid vs jbod tech can be both fast depending on how you arrange data on jbod
me either.I got it, I just never heard the term used relative to drives.
the separate memory channels support multi-threading with multi-core processors with increased performance gains.
Quad channel would have more latency and less bandwith than dual channel but probably by a little difference.
The memory sticks running in quad channel are on both sides of the processor where with dual channel they are all together in one spot close together.
From what i am seeing here, the only advantage quad channel boards have over dual channel boards is support for more memory.
Not sure on latency, but bandwidth certainly increases significantly...not a little difference.TL;DR
