Lian Li 351 case (11.5cm height limit) and asus rampage iv gene motherboard (center of the cpu area to first pci slot= 7cm).
I don't want to use liquid solutions, because i will have to modify the case since there is no extra space for fans (3 pre-installed in the case).
So the only thing i found that DOES support 130w cpu (i7 3820), was the Noctua Nh--L12. I was sure this was the solution, untill i saw that it would block the gpu in the first pci slot. I still have not understood if that cooler can be installed in a sideways way. Anyone knows?
The other solutions i have are the Suriken Big 2 Rev B, i found the dimensions, of the non-lga2011 part (the original Surikhen Big 2) and i see that if i use 3cm tall ram in quad then the cooler will be just a couple of milimetres away from the gpu. So i can't be 100% sure for the size and compatibility. Besides that, i see written that it is not recommended for above 100w cpus.
And then the other solution is the Intel Thermal solution, the simple lga 2011 cpu fan.
Am I in a dead end or what?
