hmmm, mikesm, thats a really unique idea i haven't ever heard of... if carried out right, e.g. all things have also a ground wire connecting to each other, not just all things are grounded, then it should work...
CrashOveride said:Anyone know if it is possible to get small amounts of antifreeze?
moz_21 said:
Y'know your neighbors car that never *seems* to be driven?
CrashOveride said:
Well its a Water/Antifreeze mixture in the engine coolant so I would have to take more and I wouldn't really be sure how much I would need to take. It would also be kinda hard to get it out without inhaling some fumes (unless you were implying that I cut the tubes...).
I considered taking some from my car.
moz_21 said:
The fumes ain't gonna hurt you, just don't drink it.
If you get the jugs of antifreeze, some are premixed with distilled water (50-50?)
Otherwise, a local shop or something could help you out - it won't take maybe a cup, if that. 5% antifreeze total as mentioned (somewhere)above - but I have no idea of a system's capacity so maybe more than a cup.
I am planning an adventure into w/c'ing though - thats why I am so interested in this thread.
mikesm said:Does it help to make sure the various metal elements in the watercooling loop are all grounded? If there is no potential between any of the metal parts, doesn't that prevent galvanic corrosion?
Thanks,
Mike
Having the dissimilar metals electrically isolated from each other is like having a battery sitting on a shelf. Chemical reactions still occur in the battery, and the battery will slowly go dead, but at nowhere near the rate it would if the battery was powering something. (Or shorted out.)
