- Jun 22, 2006
- Japan, California, Maryland
Hi guys.
I'm sure everyone knows the LianLi PC-V1000B these days - and that's what I'm planning on using for my new system. I'm trying to build the rig for silence as well as performance because I'd like to OC my CPU and GPU (though I don't know how much a 7900GT will give, as they use the 7900GTX cores that couldnt clock high enough).
Technical specs:
AMD Athlon64 X2 42/4400 (we'll see how cheap I can get em in a month after price drops)
GeForce 7900GT
ASUS M2N-SLI Deluxe motherboard (yup, going AM2)
2GB RAM, probably Corsair
DVD/CD-RW, going Plextor, SATA version
1x 74gb Raptor (16mb cache ver.)
1x 320gb Barracuda (7200.10) (16mb cache, NQC)
That being said, I'm planning on getting CPU, GPU, and chipset blocks and cooling them all in 1 loop.
Watercooling gear:
Haven't decided exactly what yet.
I'd like to mount a 120mm rad in the front bottom HD area, as I'm sure many people have seen before. I'd also like to mount another 120mm rad in the top 5.25" drive bay - cut a hole in the top of the case and get a nice grill. Will 2 120mm rads perform well?
As for the waterblocks, not too sure what is the best. People say that the Swiftech Apogee is great - better than DangerDen. Worth getting? Also Swiftech's chipset and GPU blocks are good as well. What do you think? Its said that the 7900GT's RAM runs a lot cooler than the 7800-models and that RAMsinks are enough for cooling, is this true?
Res - I'd like to get a drivebay res but I think I may not have room. Im which case I'll have to think of something. About drivebay res'es though, I've heard that they are sloshy, that is they make a lot of water sounds. Is this true? Can anyone reccommend one that is silent? If I can't fit a drivebay res, I guess I'll mount a small cylindrical res in the top of the case, or get that small, vertical res from alphacool (I think they make it...)
I'd also like to get the quietest pump possible. Of course I'm building a rig for cool temps, but also silence. I've heard that the DDC is the quietest pump out there, so I'm thinking about getting one. My question is, is it strong enough to pump through 2 120mm rads, a res, and 3 waterblocks? Hopefully it is, but if it isn't I guess I can always get 2 and hook em up in series.
Supposing the DDC isn't enough, how about using the alphacool top with the vertical intake port? Would that boost it? Or a DDC+, normal, or with alphatop mod? If I have to get 2, I would like to get this new Alphacool top.
I want to use smaller tubing, not 1/2" ID. I've used it before and, not that it was bad, but in this situation things will be too cramped and it'd be easier to use something like 3/8" ID. Is there anything smaller? I know that the AquaComputer parts and other german parts use smaller tubing - 1/4" (6mm)ID and 1/3" (8mm)ID I think. What size is best to go with?
Anyways, thoughts and suggestions are welcomed and needed!
Thanks guys!
When I get the parts and start working I'll make sure to create a worklog.
(BTW - if anyone knows any modders who are skilled aluminum workers, let me know. I'm looking for someone to build a small encasing for which I've made designs for - Thanks)
Technical specs:
GeForce 7900GT
Watercooling gear:
Thanks guys!
