ok guys. this question has been rattling around in my head for a while and i havent been able to find a simple answer. what is the difference between desktop and server CPUs? how are server CPUs for overclocking and graphics?
The sever systems I've seen have robust memory error checking (chipkill is the only one I can remember). Some of them actually scan the memory for errors and auto-correct, which noticeably degrades performance if a memory stick is actually bad (this requires ECC).
Check for motherboard memory support.
Some consumer motherboards support ECC memory, some do not.
Expect all server motherboards to support ECC memory.
Save your $$ and buy a desktop CPU for a desktop rig. Most of the reasons are already listed, Slower speed, less or No OC capability, different PIN configuration potentially, Memory/MB compatibility, higher temps, etc...
ECC memory and chipkill slow memory access. Because you can't be checking for errors without introducing additional latency of some kind. Some server BIO's will actually disable RAM that throws too many errors (e.g. IBM x3550-M3).
