- Aug 5, 2002
- Brisbane, Australia
I was lucky enough to grab a P4 3.4E 550 cpu on Christmas Eve to go with my 2nd hand DFI Lanparty 875P-T motherboard that I bought off Oppainter at xtremesystems.org forums Had a few initial problems in that the system didn't boot up but loosening the G4 Storm waterblock's mounting screws a bit on the DFI Lanparty 875P-T allowed it to boot.
System:
P4 3.4E 550
SL7J8
Q433A423
Nov 26, 2004
Malaysia
DFI Lanparty 875P-T with 11/30 bios
2x 256MB KHX3200K2/512 BH-5
64MB Albatron MX480EL (for testing)
120GB WD 1200JB
Pioneer AO5 DVD Burner
580W Topower 686P6 Adjustable rail PSU
CPU cooled by:
Cathar's G4 Storm waterblock with revised stepped base addition for LGA775 cpus
Swiftec MCP650 Pump
Thermochill 120.3 with 3x 120x38mm Panaflo 103cfm fans on 3.5" Rheobus 13W per channel
Dangerden fill port
Clearflex 1/2" ID tubing
Stock benchmarks:
Winbond Hardware doctor
CPUZ Idle
Sandra 2005
CPU = 10,017 / 4,100/7,055
CPU Multimedia = 24,083 / 32,236
Buffered = 5,049 / 5,043
Unbuffered = 2,914 / 2,957
Everest Home
Read: 5,808 MB/s
Write: 2,056 MB/s
Latency: 80.3 ns
Super Pi unpatched
1M = 38s
2M = 1min 26s
8M = 6min 47s
Super Pi patched
1M = 34s
2M = 1min 19s
8M = 6min 18s
StressPrime 2004
16+ mins
Overclocking:
I still haven't found my way around the bios options and not sure how well this memory performs on the 875P-T yet but I was able to boot and take this screenie at stock vcore - not stable
http://www.fileshosts.com/DFI/875P_...0-2226-15.6-FTM-CPC-SCPC-1.4-3.2-1.7/cpuz.jpg
Not bad temperature wise which was my main concern. I just have to test all my memory on this setup and see what works. I haven't installed my OCZ DDR Booster yet but I know it works with this motherboard so can pump more vdimm into my memory
So having a 875P chipset, does it also have the same affect in that 2x 512MB will result in more bandwidth than 2x 256MB memory modules ? I'll find out soon
Note: Seems the Winbond Hardware doctor's reported 12v rail is off off a bit, it shows 12.24-12.38v but from multimeter it says 11.98v idle and 11.94v load. So i'v raised it to 12.20v idle and see if that helps
System:
P4 3.4E 550
SL7J8
Q433A423
Nov 26, 2004
Malaysia
120GB WD 1200JB
CPU cooled by:
Swiftec MCP650 Pump
Dangerden fill port
Stock benchmarks:
CPUZ Idle
Sandra 2005
Everest Home
Read: 5,808 MB/s
Write: 2,056 MB/s
Latency: 80.3 ns
Super Pi unpatched
1M = 38s
2M = 1min 26s
8M = 6min 47s
Super Pi patched
1M = 34s
2M = 1min 19s
8M = 6min 18s
StressPrime 2004
16+ mins
Overclocking:
