- Dec 21, 2003
- Austin, TX
OK, I solved the problem, but gained a new one.
The ram was auto timed by the motherboard to be 5,3,3,2 which was way too tight. When I losened them timing up I got up to fsb 274.
However, the motherboard seems to have problems with the ram now. When I boot, the loading screen says the ram is running at 20 mhz. This happened down do around fsb 266 and then it registers correctly and says like ddr425 (i'm operating in a 5:4 divider). My ram is rated to ddr433, so it should be having any problems. CPUZ recognizes 512mb ram, but can't tell what kind or what speed and says there is a "driver error" when I load it up.
Why is the motherboard unable to detect the ram properly at startup when I am running the ram slower than its stock speed?
Anyone have any info? Thanks in advance!
