- Nov 30, 2004
HI I have a DFI lanparty ut nForce3 250 Gb mobo and would like to know what is a safe setting for the chipset Voltage . curently over clocking the heck out of this and have the chipset voltage up to 1.64 - 1.66 that is what smartguardin is telling me . I have corsair twinX XMS pro memory Over volted to 2.59-2.6 and have the A64 3200+ CPU Running at CPU Clock 2584.57 MHz . the system seems to running fully stable at thies settings .
CPU Type AMD Athlon 64
CPU Alias Newcastle S754
CPU Stepping DH7-CG
CPUID CPU Name AMD Athlon(tm) 64 Processor 3200+
CPUID Revision 00000FC0h
CPU Speed
CPU Clock 2584.61 MHz
CPU Multiplier 11.0x
CPU FSB 234.96 MHz (original: 200 MHz, overclock: 17%)
Memory Bus 234.96 MHz
CPU Cache
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard ID 09/14/2004-nForce-CK8S-6A61CD49C-00
Motherboard Name DFI LANParty UT nF3 250Gb (5 PCI, 1 AGP, 3 DDR DIMM, Audio, Gigabit LAN)
Chipset Properties
Motherboard Chipset nVIDIA nForce3 250Gb, AMD Hammer
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
SPD Memory Modules
DIMM1: Corsair CMX512-3200C2PRO 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
DIMM2: Corsair CMX512-3200C2PRO 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
BIOS Properties
System BIOS Date 09/14/04
Video BIOS Date 03/03/24
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message (N32LD914) EVALUATION ROM - NOT FOR SALE
DMI BIOS Version 6.00 PG
Graphics Processor Properties
DirectX 4.09.00.0904 (DirectX 9.0c)
Video Adapter ATI Radeon 9800 Pro (R350)
GPU Code Name R350 (AGP 8x 1002 / 4E48, Rev 00)
GPU Clock 378 MHz (original: 378 MHz)
Memory Clock 338 MHz (original: 338 MHz)
Sensor Properties
Tsystem 36 °C (97 °F)
Tcpu 37 °C (99 °F)
Taux 38 °C (100 °F)
Fcpu 2009 RPM
Vcore 1.55 V
V2.5 1.65 V
Vio 3.22 V
any help is greatly appretiated thank you..
one more thing can any one please help me get the most out of this system.
the DFI mobo has so many settings that I am confused as to what to do. the stabilaty of this setup is not good had to take it back down to 2508Mhz the Vcore and memory are still my main ishues here and I realy could use some expert advice on how I can get this rig up to the max . it was much easyer when I had th 3200+XP AMD chip . now it is all but impossable for me . this is why I turn to you all . thank you very much and hope to hear some thing from you all soon..
CPU Stepping DH7-CG
CPU Speed
CPU Cache
Chipset Properties
SPD Memory Modules
BIOS Properties
Sensor Properties
Tcpu 37 °C (99 °F)
Taux 38 °C (100 °F)
Fcpu 2009 RPM
Vcore 1.55 V
V2.5 1.65 V
Vio 3.22 V
