I managed to get the ram stable at stock io voltage... Made a stupid mistake, I was running the ram at 1.5v, upped it to 1.6v and now everything is fine!
Now i know i have some overclocking headroom
With my original (bad ram) The voltage was auto @ 1.5v (What they are rated at). The new ram was auto set to 1.5v even with xmp, they are 1.65v kit. I have them running at 1.6v stable. Can probably get them running at a lower voltage yet (errors were not many @ 1.5v) but i don't have the time to test for proper stability.
Just don't be surprised if down the line the memory becomes unstable if you run it at less than factory recommended voltages but with XMP timings and frequency.
If the memory ages and is no longer stable at 1.6v I can always increase to 1.65v Besides i don't expect to be using this computer before that is a problem.
Anyways, thanks for all your help. If i didn't ask here i probably would have suspected my mobo as being bad and would have had to spend some $$$$!
Thanks!
