Buck 39 here, I generally buy around 8lbs per thing being cooled.
If it's a high burn CPU like a 950 or especially a 980x I'll buy twice that.
If there's a video card involved that uses a PCIe connector, add a brick per PCIe power connector per six hours. That'll get you something decent.
What you gotta balance is on one hand, running outta dice sucks.
On the other hand, having something go "pop" when you're 10% of the way through your $45 dice load sucks too.
Have backup stuff to bench, that's my advice.
Two full systems ideally. A spare mobo is arguably the most important, they're where dubious insulation will show up as wetness and end a session, or at least put a major damper in it in the process of warming up, taking the pot off, taking all the insulation off, heating the board up and drying it off, reinsulating, etc.
That's why I usually only get one brick.
Sidenote: Put some hot soapy water in the sink and toss some dice in.
2.sidenote: I've been watching the sopranos, can you tell?
$0.80 here if I buy 15lbs or more, if not I'm spending $1.50/lb. So pretty much no reason to not buy 15lbs or more, even if a little goes to waste.
I am curious, what store offers that deal? Just asked my local publix and it's $1.49 here.
Mine is a place called Capital City Ice, not sure if they are located anywhere else. Comes in pellets as well there, instead of a block.
