- Oct 20, 2009
howdy,
as I posted in this forum before I had a brand new setup built. I am running 2 loops. I am using (2) DDC 3.25 pumps with the XSPC Dual top per loop.
About 10 days ago I had a problem with one of the DDC's on the GPU loop just stopped spinning. Completely dead. I tried connecting it to another molex (known working) and it still did not even attempt to spin. I got a replacement pump, replaced it with the bad one, and it spun up first time no issue.
Last night I turned off my system and it was off for about 12 hours. Today I went to turn it on and one of the DDC's on the different loop attempts to start spinning and stops (it doesn't spin "fast" you can see the impeller rotate though)..it tries to do this a few times. All the other pumps are working flawlessly. I disconnected the molex for the bad pump and re-connected it once everything was running. Once again it tries to start and then stops..There is nothing blocking the impeller and the system has not even been moved/touched since I last turned it off.
I bought the initial 4 pumps all at the same time, and I imagine they came from the same batch. I am seriously wondering if I just got a total faulty set of pumps?
I was a little worried when the first one gave out, but I thought that was just bad luck...now I am having serious second thoughts on what is going on. Before this incident and then last everything is running fine...no weird noises or anything like that from the pumps.
Power supply is a Corsair 1000HX and everything else is running to specs (voltages, etc.)...NOTHING HAS CHANGED SINCE I TURNED THE DAMN SYSTEM OFF AND IT WAS SPINNING FINE! It's not a matter of the pump being hot, etc...I am completely perplexed.
Any ideas/experiences?
